Gidgriff
Nov 08, 2022Guide
XR500 to replace Sky router on FTTP
Hi guys, looking to replace my sky Q router with the XR500. Has anyone done it? I have tried and it asks for generic logins from ISP which I found online but still cannot get it to work. Anyone manage...
- Nov 09, 2022Go to the Settings page and the first page it gives you, Internet Setup, scroll all the way to the bottom and it should be there
michaelkenward
Nov 09, 2022Guru - Experienced User
Gidgriff wrote:
Found it! Wasn’t showing on the PPPOe section so changed it and I’ve found it! Thanks guys 🙂
Did it fix the thing?
If so, mark this as solved and you'll help any poor soul who lands here with the same challenge.
Gidgriff
Nov 09, 2022Guide
Yes it did! Basically had to bypass the initial set up to get to that part. But all good!
- michaelkenwardNov 09, 2022Guru - Experienced User
Excellent. Those hidden ones are the hardest to find and the most useful to flag up.
- FURRYe38Nov 10, 2022Guru - Experienced User
Enjoy. 📡
Gidgriff wrote:
Yes it did! Basically had to bypass the initial set up to get to that part. But all good!- GidgriffDec 02, 2022GuideHi all, all was going ok until today. Something has happened, router lost connection this morning so I rebooted the router and since I’ve had awful latency issues. Went to game earlier and my in game latency was shooting up from 30 to 200-300 and then even up to 999!
Any suggestions or known fixes?- Netduma-FraserDec 02, 2022NetDuma PartnerWhat are your QoS Settings? Could you provide a screenshot of the page?
