Gidgriff
Nov 08, 2022Guide
XR500 to replace Sky router on FTTP
Hi guys, looking to replace my sky Q router with the XR500. Has anyone done it? I have tried and it asks for generic logins from ISP which I found online but still cannot get it to work. Anyone manage...
- Nov 09, 2022Go to the Settings page and the first page it gives you, Internet Setup, scroll all the way to the bottom and it should be there
Netduma-Fraser
Dec 03, 2022NetDuma Partner
That's quite a high percentage, we usually recommend starting off at 70%, see if that improves it.
Gidgriff
Dec 03, 2022Guide
I’ve plugged back in my Sky router, same issue there so must be ISP issue I’d assume?
- Netduma-FraserDec 03, 2022NetDuma PartnerYes that would indicate an issue on the ISP side, perhaps congestion in your local area
