Deijeneiro
Jun 03, 2021Guide
XR500 to XR1000
Hi guys , Todat I want to upgrade. Currently on the XR500. My question is the DUMA OS 3.0 better the the xr500 beta version. Because because of the many bugs I’m currently not satisfied with the XR50...
Netduma-Fraser
Jun 03, 2021NetDuma Partner
It is more polished on the XR1000 yes, it's still a very new router though so there will be some bugs of course, nothing is perfect but we'll get those sorted. Has the .120 beta version on the XR500 not worked well for you?
- DeijeneiroJun 03, 2021Guide
Did not work well for me idd.
Now next problem I bought the XR1000, fresh out of the box...
DumaOS not loaded yet!
Don't worry we will redirect you shortly.
Did everything already!? its not like a few bucks or something!????
- Netduma-FraserJun 03, 2021NetDuma PartnerWhat web browser/device are you using to access the interface? Is the router plugged directly into a wall outlet or an extender?
I tried google chrome and microsoft Edge. I'm a bit further now.
I get haserl CGI Error
Failed to readline from 'config get DumaOS_Theme_Version'
now!?
tried rebooting, still the same.
