Dreddpool82
Sep 14, 2019Aspirant
XR500 TypeError: frame.contentWindow.browserSetup is undefined
Recently i attempted to update my firmware when I cam across 2 problems 1 being the TypeError: frame.contentWindow.browserSetup is undefined?? No idea what that means and the second being that i con...
Netduma-Fraser
Sep 14, 2019NetDuma Partner
Do you get that first error on any specific page on the router? Does it appear after doing something or is it always present? For the second issue, access the interface using the LAN IP, does that resolve it?
- Dreddpool82Sep 14, 2019Aspirant
The type error appears as soon as i login and the other one shows up no matter what link on the left side i click.
My internet works fine , it's just the router OS is stuffed.
As to the 2nd one it don't matter if I'm connected via Lan or WiFi it still shows up and my browsers are all up to date.- Dreddpool82Sep 14, 2019Aspirant
I have uploaded a short clip to youtube, so you can see the exact problem in action.
https://www.youtube.com/watch?v=Llr7eM6cdHg&feature=youtu.be- Netduma-FraserSep 14, 2019NetDuma PartnerI meant using the IP instead of routerlogin.net to access but thanks for the video I can see you're already doing that. You said you attempted to update your firmware, does that mean you're on the newest firmware .56 or still on the previous version?
