Dreddpool82
Sep 14, 2019Aspirant
XR500 TypeError: frame.contentWindow.browserSetup is undefined
Recently i attempted to update my firmware when I cam across 2 problems 1 being the TypeError: frame.contentWindow.browserSetup is undefined?? No idea what that means and the second being that i con...
Dreddpool82
The type error appears as soon as i login and the other one shows up no matter what link on the left side i click.
My internet works fine , it's just the router OS is stuffed.
As to the 2nd one it don't matter if I'm connected via Lan or WiFi it still shows up and my browsers are all up to date.
Dreddpool82
I have uploaded a short clip to youtube, so you can see the exact problem in action.
https://www.youtube.com/watch?v=Llr7eM6cdHg&feature=youtu.be
- Netduma-FraserSep 14, 2019NetDuma PartnerI meant using the IP instead of routerlogin.net to access but thanks for the video I can see you're already doing that. You said you attempted to update your firmware, does that mean you're on the newest firmware .56 or still on the previous version?
- Dreddpool82Sep 14, 2019Aspirant
I am using the IP address a s it's faster.
i have no idea what number firmware is as nothing stays on screen long enough for me to read it as you can see in the clip i made.
I did manage to click check for updates and it said it was up to date.- Dreddpool82Sep 14, 2019Aspirant
It's midnight here so I will check this post in 8hrs.
Got this off the system info page V2.3.2.56
