Dreddpool82
Sep 14, 2019Aspirant
XR500 TypeError: frame.contentWindow.browserSetup is undefined
Recently i attempted to update my firmware when I cam across 2 problems 1 being the TypeError: frame.contentWindow.browserSetup is undefined?? No idea what that means and the second being that i con...
Netduma-Fraser
Sep 21, 2019NetDuma Partner
Take the full stop off the end of it and try again please
Dreddpool82
Sep 21, 2019Aspirant
ok it's disabled in chrome now, but i still get the same problem.
- Dreddpool82Sep 21, 2019Aspirant
You may not believe this but I think I figured out what was causing the problem, I have AVG Anti track and when i quit it, my routers os is no longer disconnecting.
Edit: yep it's the AVG anti Track program, as when i open it by doubling clicking it's desktop icon, i get the connection problem.
I will contact them tomorrowand let them lnow that it's causing problems with connecting to my router.
You may also want to contact them and see if there is anything they may need to knpow about this routers OS, that could help fix the problem.
EDIT Edit: I'm still getting "TypeError: can't redefine non-configurable property "userAgent" message.- Netduma-FraserSep 21, 2019NetDuma PartnerWell done, good catch, we have identified an issue caused by some Anti-Virus before but haven't seen it with AVG yet. If you do a reset does that message disappear?
not sure what you mean by reset?
If i quit the avg anti track(the icon in the bottom right of task bar) so it's no longer running in the back ground, the problem is gone.
As soon as i turn it back on it starts having the problem again.As to the reset are you talking about the Router and resetting it back to factory default?
we did that already and it didn't fix anything, resetting now would have the same results as soon as Anti track starts the problem appears, like i said when i quit AVG Anti Track the problem is gone.
