Rastaa
Feb 23, 2020Aspirant
XR500 unable to connect to network
Just got my first gaming router and im trying to connect wirelessly to my PC (Windows 10) and iPhone X. The router comes up in the list of available networks but whenever i type the password it says...
Netduma_Alex
Feb 24, 2020NetDuma Partner
Did you change the default SSID and password? If not, then the password should be the one on the sticker on top of the unit.
If this doesn't work, you could always do a factory reset using the button on the back. This would put it back to the default SSID and password.
Rastaa
Feb 24, 2020Aspirant
Ive tried factory resetting it and i havent actually been able to connect once to the router to change anything.
- Netduma-FraserFeb 25, 2020NetDuma PartnerThe WiFi details would revert back to the details on the sticker on the top of your router. Otherwise connect via ethernet, go through the setup wizard and make the changes to the wifi. Once you've finished the setup wizard then connect to the wifi and see if it works.
