modernhistorian
Oct 10, 2018Initiate
XR500 unkown devices
I've been using the XR500 router for a few weeks, and have two questions. Is there any way to turn off the Dumas OS tour upon loading the web page? I have gone through to the end and clicked "Done," ...
- Oct 11, 2018That tour should only appear after a factory reset. To get rid of it just go to routerlogin.net without anything after it in the URL bar and it won't appear again.
Do you have an Access Point connected to the router? It may actually be a wireless device connected. No way to blacklist MAC address but you could block it from the device manager if you're concerned.
Netduma-Fraser
Oct 11, 2018NetDuma Partner
- modernhistorianOct 11, 2018Initiate
That worked. I had Chrome bookmarked the DumaOS Desktop after installation and it retained the tour.
No AP, just a "dumb" network switch. I found it, however. There's a DirecTV DVR, with a mini attached to it via coax. The DirecTV is a wireless connection and properly labelled, but the mini gets assigned a wired connection for some reason.
Thanks for your help.
