apszczolkowski
Mar 20, 2021Tutor
XR500 update 2.3.2.114
I recently updated to version 2.3.2.114 and now my geo-filter isn’t allowing me to create boxes. It’s only the circle now. Also the ping heat map is no longer a side option. Is there a fix to this? Or...
michaelkenward
Mar 21, 2021Guru - Experienced User
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
I will ask the Netgear moderator to move your message.
