Retired_Member
Sep 29, 2022XR500 Update Question
I have a question about updating on the xr500. Do I need to factory reset first before updating or update first then factory reset? Also What seems to be the most stable firmware right now?
- Oct 01, 2022It's been out for awhile so it's quite stable, if you aren't having any issues on your current version and you don't want to rock the boat then you could stay on your version. Just keep in mind you may not have the latest security fixes.
Sep 29, 2022Guru - Experienced User
Afterwards.
I recommend setting the DHCP default IP address pool size to .100 to .200 after you factory reset and setup from scratch.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Retired_Member
Sep 29, 2022I’m using the cm700 modem
- Netduma-LiamSep 30, 2022NetDuma Partner
OK sounds good, feel free to complete the steps FURRYe38 recommends and you should be good to go!
- Retired_MemberSep 30, 2022Do I need to factory reset before update or after?
- Retired_MemberSep 30, 2022Also I’m trying to find the best firmware out right now. Any suggestions?
