Retired_Member
Sep 29, 2022XR500 Update Question
I have a question about updating on the xr500. Do I need to factory reset first before updating or update first then factory reset? Also What seems to be the most stable firmware right now?
- Oct 01, 2022It's been out for awhile so it's quite stable, if you aren't having any issues on your current version and you don't want to rock the boat then you could stay on your version. Just keep in mind you may not have the latest security fixes.
Retired_Member
Sep 29, 2022I’m using the cm700 modem
Netduma-Liam
Sep 30, 2022NetDuma Partner
OK sounds good, feel free to complete the steps FURRYe38 recommends and you should be good to go!
