Retired_Member
Sep 29, 2022XR500 Update Question
I have a question about updating on the xr500. Do I need to factory reset first before updating or update first then factory reset? Also What seems to be the most stable firmware right now?
- Oct 01, 2022It's been out for awhile so it's quite stable, if you aren't having any issues on your current version and you don't want to rock the boat then you could stay on your version. Just keep in mind you may not have the latest security fixes.
Retired_Member
Sep 30, 2022Do I need to factory reset before update or after?
Retired_Member
Sep 30, 2022Also I’m trying to find the best firmware out right now. Any suggestions?
- Netduma-LiamSep 30, 2022NetDuma Partner
It's always suggested to use the latest, which your router should already be running if it's auto-updated. Which firmware version are you currently running?
- Retired_MemberSep 30, 2022V2.3.2.114
- Netduma-FraserOct 01, 2022NetDuma PartnerThe latest is .134 so you can manually do it by downloading the file here: https://kb.netgear.com/000064857/XR500-Firmware-Version-2-3-2-134 then uploading it in Settings > Administration > Firmware Update on the interface or go to the same place and allow it to auto upgrade
