Retired_Member
Sep 29, 2022XR500 Update Question
I have a question about updating on the xr500. Do I need to factory reset first before updating or update first then factory reset? Also What seems to be the most stable firmware right now?
- Oct 01, 2022It's been out for awhile so it's quite stable, if you aren't having any issues on your current version and you don't want to rock the boat then you could stay on your version. Just keep in mind you may not have the latest security fixes.
Sep 30, 2022Guru - Experienced User
Afterwards.
- Retired_MemberSep 30, 2022Ok you still didn’t answer my 2nd question. Which firmware is most stable currently or what would you suggest? Don’t know why support is so hard to get around here.
- FURRYe38Sep 30, 2022Guru - Experienced User
Try what's currently loaded on the router, "if the router works, don't fix it."
