Retired_Member's avatar
Retired_Member
Sep 29, 2022
XR500 Update Question
I have a question about updating on the xr500. Do I need to factory reset first before updating or update first then factory reset? Also What seems to be the most stable firmware right now?
  • Netduma-Fraser's avatar
    Netduma-Fraser
    Oct 01, 2022
    It's been out for awhile so it's quite stable, if you aren't having any issues on your current version and you don't want to rock the boat then you could stay on your version. Just keep in mind you may not have the latest security fixes.
