tfsawmill
Jan 21, 2020Tutor
Xr500 upgrade from dsl to fiber
Hi, I'm upgrading my internet from dsl to fiber. I remember when I set up my xr500 it tested my Max download speed (14 mbps) and that's what my settings are based off of. When the fiber is hooked up i...
- Jan 21, 2020I'm hoping to avoid a total reset since I have alot hooked up via WiFi (smart home). And it's the same isp. They're just upgrading their equipment. So I'll try just inputting speed test results in buffer bloat. Thank you.
Jan 21, 2020Guru - Experienced User
Whenever I change providers, I always prefer to re-do my setup from factory. It prevents old/forgotten settings from causing issues.
Unless you have a advanced configuration, I'd factory reset the device and start over.
If you do have a complex setup and don't want to redo the configuration, I'd take a look at the DumaOS QoS guide.
http://support.netduma.com/support/solutions/articles/16000077073-dumaos-optimal-settings-guide-qos
- Netduma-FraserJan 21, 2020NetDuma PartnerYou can do the above or start the setup wizard again from the Settings page. Alternatively you could do a wired speedtest.net test when nothing it using the internet and then input the results into the Bandwidth section in the options of Anti-Bufferbloat on the QoS page.
- tfsawmillJan 21, 2020TutorI'm hoping to avoid a total reset since I have alot hooked up via WiFi (smart home). And it's the same isp. They're just upgrading their equipment. So I'll try just inputting speed test results in buffer bloat. Thank you.
- tfsawmillJan 21, 2020TutorThanks
