tfsawmill's avatar
Jan 21, 2020
Xr500 upgrade from dsl to fiber
Hi, I'm upgrading my internet from dsl to fiber. I remember when I set up my xr500 it tested my Max download speed (14 mbps) and that's what my settings are based off of. When the fiber is hooked up i...
  • tfsawmill's avatar
    tfsawmill
    Jan 21, 2020
    I'm hoping to avoid a total reset since I have alot hooked up via WiFi (smart home). And it's the same isp. They're just upgrading their equipment. So I'll try just inputting speed test results in buffer bloat. Thank you.
