Consumer0129383
Sep 03, 2019Luminary
XR500 Upload Speed is in single digits on gigabit internet
Ok, My XR500 is producing lower speeds than expected. Ran a speed test and my Ping is 14ms, Download is 793.65, and upload is 8.94. On the google fiber network box alone I get 900's on both upload an...
- Dec 19, 2019Was having the same problem. It's them. My router has been collecting dust for 10 months now and i can't find a local buyer. $300 down the drain. I switch to my isp's modem/router because it's giving higher download and upload speeds in my Xbox network test. Even downloading games my speed detection is like 4-5 times higher. What really suffers is the upload speed detection. Ipay for a gig up and down. Getting 800-900 down and about 300 to 500 up with my isp's box. I get around 700-800 down with xr500, but only 20 upload max. I've tried everything. Also, downloading games with xr500 60-140mbps. Isp box between 230-360ish.
Intrickit27
Dec 19, 2019Aspirant
Netduma_Alex
Dec 20, 2019NetDuma Partner
Sorry to hear you've been dissapointed by your XR500...
When it was connected, did you have it connected to an ISP router/modem or a generic modem? Or an ONT?
Also when DumaOS 3.0 comes out it will be totally worth whipping out the olde XR500 again.
- Intrickit27Dec 20, 2019AspirantMy ISP modem. It wasn't a combo.
- Netduma_AlexDec 20, 2019NetDuma Partner
So it's the same modem you're using now with the router that's working better?
