Consumer0129383
Sep 03, 2019Luminary
XR500 Upload Speed is in single digits on gigabit internet
Ok, My XR500 is producing lower speeds than expected. Ran a speed test and my Ping is 14ms, Download is 793.65, and upload is 8.94. On the google fiber network box alone I get 900's on both upload an...
- Dec 19, 2019Was having the same problem. It's them. My router has been collecting dust for 10 months now and i can't find a local buyer. $300 down the drain. I switch to my isp's modem/router because it's giving higher download and upload speeds in my Xbox network test. Even downloading games my speed detection is like 4-5 times higher. What really suffers is the upload speed detection. Ipay for a gig up and down. Getting 800-900 down and about 300 to 500 up with my isp's box. I get around 700-800 down with xr500, but only 20 upload max. I've tried everything. Also, downloading games with xr500 60-140mbps. Isp box between 230-360ish.
Netduma_Alex
Dec 20, 2019NetDuma Partner
Sorry to hear you've been dissapointed by your XR500...
When it was connected, did you have it connected to an ISP router/modem or a generic modem? Or an ONT?
Also when DumaOS 3.0 comes out it will be totally worth whipping out the olde XR500 again.
Intrickit27
Dec 20, 2019Aspirant
My ISP modem. It wasn't a combo.
- Netduma_AlexDec 20, 2019NetDuma Partner
So it's the same modem you're using now with the router that's working better?
