Retired_Member
Jun 11, 2022XR500 USB Printer Support
Hi guys, I am trying to connect my Samsung SCX-3200 Printer to my router however it is not detected on the routers web page, nor can I see it using the USB software from Netgear. I see the USB LE...
- Jun 12, 2022Have a look at page 168 of the User Manual, that should help you get up and running: https://www.downloads.netgear.com/files/GDC/XR500/XR500_UM_EN.pdf
Netduma-Fraser
Jun 12, 2022NetDuma Partner
- Retired_MemberJun 12, 2022
Fraser,
Weirdly, It is now working... I changed nothing except reconnected the damn thing! I spent hours trying to sort this bloody thing yesterday!
Thanks,
Chris
