cosmo2450
Jun 07, 2020Guide
Xr500 usb
I have two xr500 and I use one in AP mode. I have flawless wifi in my house. But in regards to the USB that’s plugged into the main xr500, how do I access this on my IOS phone. Netgear genie had a goo...
Jun 08, 2020Guru - Experienced User
Is it visible from other devices?
This article might have some tips.
cosmo2450
Jun 08, 2020Guide
It sure is. Both PC and Mac and easily transfer things to and fro. Like I said, netgear genie was great for this, but the “upgraded” nighthawk app lacks it.
I tried through the files app too (as suggested in that article). No luck there. Hopefully netgear bring back this function
- Netduma-FraserJun 09, 2020NetDuma PartnerJust to double check, did you use the server & user details from the ReadyShare page when trying to access using files?
- cosmo2450Jun 09, 2020GuideSo I worked this out (sort of). Instead of using http:// i did some extra reading and changed that to smb://
This allowed connection and found my USB. However!! Clicking on the main folder to open to contents of the USB it doesn’t load. All of this is on an iPhone 11 Pro.- Netduma-FraserJun 09, 2020NetDuma PartnerIf you disable admin login for that so that no login is required at all does that allow it to load?
