geomoondog
Apr 17, 2021Aspirant
XR500 V2.3.2.114 causes Media Server issue
Netgear XR500 Firmware update XR500 V2.3.2.114 and up: Once I install updates I can not play any videos anymore from Infuse 6 on my AppleTV. When I install the V2.3.2.56 it runs fine! Does anyone k...
Netduma-Fraser
Apr 17, 2021NetDuma Partner
Did you factory reset after doing the upgrade? If you disable QoS fully does it work?
- geomoondogApr 17, 2021Aspirant
Yes I have tried the factory reset and my Qos is disabled but no luck. I have downgraded back to version V2.3.2.56 and it all works fine now. Later on I will buy another router, not a Netgear and I hope not to have these kind of issues again.
- Netduma-FraserApr 17, 2021NetDuma PartnerYou could try the DumaOS 3.0 beta and see if it works as that will be the firmware we will be using going forward
If v 3 is out of Beta and I still use the Netgear router, I will try it then. For now I am fedup with Netgear.
