ngearftard
Mar 30, 2022Luminary
XR500 V2.3.2.130 checksum
Is the checksum for the above-mentioned firmware image file published publicly anywhere? I'm not finding it.
- Mar 30, 2022Totally understand, you could try reaching out to Netgear to see if they can provide that but if you are looking for more security focused features then the XR probably isn't the one for you right now. You're very welcome!
Netduma-Fraser
Mar 30, 2022NetDuma Partner
I don't believe so, they used to include the md5 in the zip file but doesn't seem like that is happening anymore, though if you're downloading directly from the Netgear support site https://www.netgear.com/support/product/XR500.aspx#download (click Support at top of the page if you don't want to use the link) then you can be sure it's official
