ngearftard's avatar
ngearftard
Luminary
Mar 30, 2022
XR500 V2.3.2.130 checksum
Is the checksum for the above-mentioned firmware image file published publicly anywhere? I'm not finding it.
  • Netduma-Fraser's avatar
    Netduma-Fraser
    Mar 30, 2022
    Totally understand, you could try reaching out to Netgear to see if they can provide that but if you are looking for more security focused features then the XR probably isn't the one for you right now. You're very welcome!
