ngearftard
Mar 30, 2022Luminary
XR500 V2.3.2.130 checksum
Is the checksum for the above-mentioned firmware image file published publicly anywhere? I'm not finding it.
- Mar 30, 2022Totally understand, you could try reaching out to Netgear to see if they can provide that but if you are looking for more security focused features then the XR probably isn't the one for you right now. You're very welcome!
ngearftard
I appreciate the prompt reply; however, a certain former government contractor who I won't name proved you can't be sure it's official due to the potential for sophisticated man in the middle attacks while downloading firmware and driver updates. If I sound paranoid, it's because that's the nature of my work. As I mentioned in the other thread, I keep my Auto Firmware Update setting on "I Disagree" and manually check for firmware updates daily, yet somehow my XR500 rebooted with no power loss (for which you provided a possible cause) and that setting was changed with no action on my part to "I Agree." It's surprising Netgear no longer publishes its firmware checksums. I can't think of any good reason why this information wouldn't be publicly available as that's a generally accepted practice in the industry. I love this router, but maybe it's time to switch to something with security more in mind. Thanks again, Fraser. You've been incredibly responsive and helpful throughout the time I've owned the XR500.
Netduma-Fraser
Mar 30, 2022NetDuma Partner
