Xr500
Mar 15, 2019Apprentice
XR500 V2.3.2.40 Two Serious Bug
Two Serious bug Reasons for appearance: Long-term uninterrupted Download Two Serious bug Reasons for probability: Each Long-term uninterrupted Download Two Serious bug Reasons for Interim s...
Mar 15, 2019Guru - Experienced User
Has a factory reset been performed after updating to v40 then setup from scratch?
How are you determining these issues?
What does long term uninterrupted download mean? Are you having problems with downloads? Would need more details on this?
You might revert to v32 and see if anything is different.
Two Serious bug Reasons for Interim solutions:
Restart using Shutdown key
First Serious bug:
Anti-Bufferbloat When operating all settings.
Error prompt:RPC error 'ERROR_NOENT': Rule not found in chain
The second Serious bug:
Internet Orange Lighting.
5Ghz and 2.4Ghz White Lighting.
Eth1 White Lighting.
Mobile phones and Computers No network.The same is true of waiting a long time.
And don't go in and Manage Pages. www.routerlogin.com Blank space nothing shows.
Must be forced to restart using Shutdown key.
:smileysad: It has happened many times. I need help.
- Xr500Mar 15, 2019Apprentice
Thank you very much for your timely reply.
- I don't know my ISP modem.Connection mode PPPoE.
- Updating a version will restore factory settings.
- WINDOWS 7 Computer Performs Download Task. The download software is BitComet. Download for about 20 hours. XR500 Problems arise.
- Previous versions did not have this problem.previous versions contained security vulnerabilities.
- FURRYe38Mar 15, 2019Guru - Experienced User
Would need to find out modem model information.
updating FW does NOT restore factory resetings.
After the update is completed. I manually restore the factory settings.
I don't feel related to ISP modem model.
Because this network is provided by the company.
When the Internet lights are orange. management pages can't get in.
When the Internet is white. the management page enters normally.
