Xr500
Mar 15, 2019Apprentice
XR500 V2.3.2.40 Two Serious Bug
Two Serious bug Reasons for appearance: Long-term uninterrupted Download Two Serious bug Reasons for probability: Each Long-term uninterrupted Download Two Serious bug Reasons for Interim s...
Xr500
Thank you very much for your timely reply.
- I don't know my ISP modem.Connection mode PPPoE.
- Updating a version will restore factory settings.
- WINDOWS 7 Computer Performs Download Task. The download software is BitComet. Download for about 20 hours. XR500 Problems arise.
- Previous versions did not have this problem.previous versions contained security vulnerabilities.
Mar 15, 2019Guru - Experienced User
Would need to find out modem model information.
updating FW does NOT restore factory resetings.
- Xr500Mar 15, 2019Apprentice
After the update is completed. I manually restore the factory settings.
I don't feel related to ISP modem model.
Because this network is provided by the company.
When the Internet lights are orange. management pages can't get in.
When the Internet is white. the management page enters normally.
- FURRYe38Mar 16, 2019Guru - Experienced User
Reason for asking about model# is to check for model information about the modem your using and nat abilities.
What prior versions of FW worked for you?
Has a factory reset been performed after updating to v40 then setup from scratch?
- Netduma_JackMar 19, 2019NetDuma Partner
This error prompt on Anti-Bufferbloat:
Error prompt:RPC error 'ERROR_NOENT': Rule not found in chain
This is very rare but can sometimes happen. Could you try rebooting your router. You shouldn't see it after that.
