Xr500
Mar 15, 2019Apprentice
XR500 V2.3.2.40 Two Serious Bug
Two Serious bug Reasons for appearance: Long-term uninterrupted Download Two Serious bug Reasons for probability: Each Long-term uninterrupted Download Two Serious bug Reasons for Interim s...
Mar 19, 2019Guru - Experienced User
What prior versions of FW worked for you?
Has a factory reset been performed after updating to v40 then setup from scratch?
Xr500
Jul 03, 2019Apprentice
Three months have passed.
My problem still exists.
i have tried many times Reinstall the FW .
factory reset been performed after updating to v40 setup.
- Netduma_AlexJul 03, 2019NetDuma Partner
Are we talking about the first problem (anti-bufferbloat) or the second problem (can't access interface)?
- Xr500Jul 03, 2019Apprentice
The first problem (anti-bufferbloat) is that it occasionally appears.
The second problem often arises.
- FURRYe38Jul 03, 2019Guru - Experienced User
Try downgrading to v32, factory reset and setup from scratch to see if problem still happens?
Xr500 wrote:Three months have passed.
OK,But my R8000 has never had these two problems.
But R8000 is not optimized for games.
- Netduma_AlexJul 04, 2019NetDuma Partner
Have you tried this hotfix firmware? https://forum.netduma.com/topic/28523-new-xr500-hotfix-firmware-for-drop-outs/
It's specifically for dropouts so it might fix your problem.
