doP0P
Mar 13, 2024Aspirant
XR500 very slow download speeds only to PC
Hello everyone, I recently purchased a CM2000 modem and XR500 router. Upon installation I performed a factory reset on both devices as well as verified that they had the most recent firmware. MY ...
Mar 14, 2024Guru - Experienced User
First test the PC with the CM modem directly with the PC. Does it get to spec speed there?
Is QoS enabled on the XR router. Speed test with QoS disabled.
Also be sure to speed test with Ooklas installable speed test app on the PC.
What is the brand and model# of the ethernet adapter in the PC?
Be sure the ethernet drivers are up to date from it's Mfr.
Test with different cabling. CAT6 Is recommended between the modem, router and PC.
What FW version is loaded on the XR500?
- doP0PMar 14, 2024Aspirant
Hi Furry, thanks for the reply. Is e38 a bimmer reference?
Anyway, I tested the modem directly to the PC and confirmed 1 Gbps
This is what it looks like with the wifi adapter
As for the router everything is set by default except for SSID. I have only been testing on speedtest.net and here are the numbers:
Wired w/QoS: 16.53 Mbps down / 0.26 Mbps up
Wired w/out QoS: 17.70 Mbps down / 0.29 Mbps up
Wireless w/QoS: 56.43 Mbps down / 0.41 up
Wireless w/out QoS: 43.63 Mbps down / 0.29 Mbps up
The brand of the ethernet adapter was Realtek. Although I switched to a Netgear AXE3000 WiFi adapter to rule out certain things. The driver for the AXE3000 was updated to the latest FW as well. I tested with different CAT 5e cables plus the CAT 8 Cable that was used for the results above. When you said CAT 6 is recommended, a CAT 8 wouldn't be better and the best cable for XR500 is CAT 6? Lastly, the FW on XR500 has the latest FW installed.
- FURRYe38Mar 14, 2024Guru - Experienced User
Yes.
What speed results did you see with the PC ethernet connected directly to the modem?
Furry,
To verify was that yes for CAT 6 being the best cable for XR500 or bimmer reference? The speed was the same as if it was wired to the router.
