Rob-xr500
Apr 13, 2021Tutor
XR500 Vigor 130 & sky broadband
Looking for some advice on changing my setup. Current setup ISP (sky fibre broadband router UK) connected to XR500. Now i was thinking of getting a Dreytek vigor130 to get rid of the sky router to ...
antinode
Apr 13, 2021Guru
Does "sky fibre broadband router UK" have a maker and model number?
To what is it connected?
Cascading multiple routers can cause multiple problems, including
"double NAT". Why are you using both these devices?
> [...] over wifi but when i try to connect playstation the xr500 with
> an ethernet cable [...]
https://community.netgear.com/t5/x/x/m-p/2083369
Starting multiple threads for one problem might not be the most
efficient path to a solution.
