Laryke
Nov 18, 2021Apprentice
Xr500 vlan201
Hello, I have a problem connecting my router to the modem, the modem use iPoe vlan-201 and I was trying to connect my xr500 via transparent bridging but it’s not working, on dumaos it tells me that t...
Netduma-Fraser
Nov 18, 2021NetDuma Partner
If that is your IP then the bridging hasn't worked at all and it is still in router mode. You can have the modem in router mode and put the XR WAN IP in its DMZ instead, then connect all devices to the XR and it will work just as well.
Laryke
I try that, but I have double nat
- Netduma-FraserNov 18, 2021NetDuma PartnerDid you put the WAN IP you mentioned there in it or another? If you put the correct IP in then you may have a CG-NAT, in which case the only way around it is to get a static public IP from the ISP
- LarykeNov 18, 2021ApprenticeI put that wan ip in there, I will try with static ip
