Laryke
Nov 18, 2021Apprentice
Xr500 vlan201
Hello, I have a problem connecting my router to the modem, the modem use iPoe vlan-201 and I was trying to connect my xr500 via transparent bridging but it’s not working, on dumaos it tells me that t...
Laryke
I try that, but I have double nat
Netduma-Fraser
Nov 18, 2021NetDuma Partner
Did you put the WAN IP you mentioned there in it or another? If you put the correct IP in then you may have a CG-NAT, in which case the only way around it is to get a static public IP from the ISP
- LarykeNov 18, 2021ApprenticeI put that wan ip in there, I will try with static ip
