U03A9
Apr 01, 2020Aspirant
XR500 VPN Service.. a joke?
I recently discovered that my XR500 has the ability to act as a VPN server (I've long used the Hybrid VPN section) and decided it would be an excellent way to SSH into my pentesting box without havin...
Netduma-Fraser
Apr 02, 2020NetDuma Partner
You may be better off creating a ticket with NG directly here: http://support.netgear.com/ as it isn't a feature we have created. As such I can only provide limited answers. Regarding the Device Manager the devices aren't shown because the router cannot control them, it shows what devices are directly connected. You definitely shouldn't have had to disable QoS, as far as I'm aware you only need DDNS enabled to use that feature.
