U03A9
Apr 01, 2020Aspirant
XR500 VPN Service.. a joke?
I recently discovered that my XR500 has the ability to act as a VPN server (I've long used the Hybrid VPN section) and decided it would be an excellent way to SSH into my pentesting box without havin...
U03A9
Apr 02, 2020Aspirant
Is this not the Netgear community site? Is it not a feature included in the Netgear routers?
Also, what do you mean the router cannot control them? Are you telling me this XR500 is running an unmanaged unmonitored VPN server on it? Who let that past security?
and you absolutely have to disable QoS. It's been mentioned and recommended... quite literally by YOU. How do you not remember this?
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/Nighthawk-XR500-cannot-use-VPN-Server-for-remote-login/m-p/1798877
Netduma-Fraser NetDuma Partner 2019-09-15 05:00 PM Re: Nighthawk XR500. cannot use VPN Server for remote login It's possible that QoS is blocking it from getting any further, disable this fully in Anti-Bufferbloat options and see if that helps at all. Message 23 of 23
It's apparently so bad that even tomsguide recommends disabling it
https://www.tomsguide.com/us/netgear-router-disable-qos,news-27675.html
Netduma-Fraser
Apr 04, 2020NetDuma Partner
I work for Netduma who created the DumaOS portion of the software. Yes but I suggested the ticket as Netgear representatives do not often reply to support here so you'd be better able to receive assistance by creating a ticket.
I'd just going on what I think is happening and I don't think it controls those devices if it's not directly connected, I may be wrong. That was a suggestion to see if it helped, not a concrete answer, I didn't get a response either so wasn't aware if it worked or not.
The tomsguide link doesn't relate to the DumaOS software so I couldn't comment on that as it's not the same software being used.
