Xentaur
Sep 21, 2021Tutor
XR500 VPN Service not working
Dear all, Was recommended to post this issue here. XR500 firmware version V2.3.2.114. I have read several posts without a solution regarding the functionality failure of the VPN Service feature i...
- Oct 08, 2021
Hi all,
Further investigation has identified that the culprit was Windows 10 Defender Firewall with Advanced Security.
After successful remote connection to the XR500 VPN Service via OpenVPN Connect I discovered I was able to ping other devices on the 192.168.1.X IP range and also browse shared folders thereon, but was still unable to do so on my Windows 10 machine.
I tried resetting the Windows 10 firewall to default settings but was still unable to access the machine via the OpenVPN connection. So, this blocking behaviour is by default.
The solution was to add an inbound rule to the firewall to permit access to the Windows 10 shared folders:
1. Open Windows Defender Firewall and Advanced Security in Windows 10
2. Select Inbound Rules in the left pane and then New Rule ... in the right pane.
3. Select Port as the Rule Type and click Next.
4. For Protocols and Ports select TCP and All local Ports and click Next.
5. For Action select Allow the connection and click Next.
6. For Profile select only Private and click Next.
7. Create a name for your rule and click Finish.
8. Double-click your new inbound rule to access the properties.
9. Select the Scope tab
10. Under Remote IP Address select These IP Addresses and click Add
11. On the IP Address form add the IP address that is assigned to your OpenVPN connection (in my case, 192.168.2.2) to the This IP address or subnet field.
12. Ok to add the IP Address, then OK to update the scope.
I found after adding the above I had difficulty accessing the Windows 10 machine from my home network, so added my home network's IP Range at step 11.
If you connect via OpenVPN to your XR500 using UDP protocol (or switch between dependent upon device) then follow the above steps to create a rule for UDP as well.
This might not be the optimal way to resolve this problem but at least now I can access my home network when I'm out and about.
I hope these steps assist others in avoiding the hours of frustration I experienced.
Cheers.
Netduma-Liam
Sep 21, 2021NetDuma Partner
Sorry to hear this!
As you mention, it's a features of Netgear's so maybe not something we at Netduma can solve but we'll do our best!
Are you getting any error messages or are there any log entries on the XR500 around the time of you connecting to the VPN service?
Xentaur
Sep 27, 2021Tutor
Hi
logs show successful connection. Between connect and disconnect I tried to access my home network but timed out.
[OpenVPN, connection drop] from remote IP address: 1.136.106.196, Monday, September 27, 2021 16:59:18
[OpenVPN, connection successfully] from remote IP address: 1.136.106.196, Monday, September 27, 2021 16:58:36
[LAN access from remote] from 193.27.228.60:58829 to 192.168.1.4:3896, Monday, September 27, 2021 16:58:34
[Log Cleared] Monday, September 27, 2021 16:58:08
So, have tried connecting on Linux Mint, windows and Android smartphone via openvpn client and configuration files downloaded from the XR500.
Each instance connects but the assigned IP address of 192.168.2.2 is not in the range I need to access my home network, which is on 192.168.1.X.
So, I can log into the router via the vpn connection but my file server is out of reach.
I would have assumed that configuration files generated via VPN Service settings in the XR500 would, based on my having selected home network access, know on which IP range my network resides and include it in the configuration.
Suggestions gratefully received.
Cheers
Cheers
- Netduma-LiamSep 27, 2021NetDuma Partner
That's interesting, what is the modem the XR500 is connected to? Is it a router/modem combo, could that be where you're somehow getting a 192.168.2.x IP from?
It may be best to raise a ticket directly with Netgear regarding this problem, you can do so at support.netgear.com.
