mrekimf
Apr 01, 2019Apprentice
XR500 vs R7000
I currently own the R7000, been having issues lately with it disconnecting my internet and I have to restart it. Its about 3years old.
So leaning towards buying XR500.
Just trying to figure out i...
Apr 02, 2019Guru - Experienced User
The XR450 is an option as well if you can't quite afford the XR500. The 450 is the same HW accept for the 2.4Ghz radio connection rate is a bit less than the 500's.
Just trying to figure out if it worth the extra money, compared to the R7000.
I have connected wirelessly 2 xboxone's, 2 laptops, 4 cell phones, 2-3 firesticks(IPTV), I do bittorrents also, then misc items like thermostat, garage door.
thank you
