Joshh's avatar
Joshh
Tutor
Oct 11, 2019
XR500 vs. XR450, which do I purchase?
Looking for a new router for my new home, the R7000 I had from 2015 was just not doing the job (range issues, random drops, etc.). I am currently looking at the XR500 and XR450. I have done some r...
  • Joshh's avatar
    Joshh
    Dec 09, 2019
    Turns out the update I had for the R7000 had issues, it could be solved by downgrading.
    I did still get the XR450 though, as I figured this out after. The router was getting old anyways.
