cbrx
Mar 19, 2020Star
XR500 Warranty Woes
My XR500 died, and I'm trying to get an RMA done. The problem is, Neatgear's website is telling me it was purchased months before it was, and is out of warranty. I have the proof of purchase from Ama...
- Jun 01, 2020
Hi cbrx,
Let me go ahead and send a follow up. Please provide me with a phone number and preferred contact time you can be contacted.
Thanks,Christian
ChristineT
May 11, 2020NETGEAR Employee Retired
Good afternoon cbrx ,
Thanks for reaching out to me and the @ mention! I am in touch with our support department regarding your open case and am working to get the resolution of your case expedited. I have been advised that an agent will be reaching out to you shortly. If that doesn't happen please let me know and I'll raise this to a higher level.
I truly appreciate the patience you have demonstrated with this issue.
Best Regards,
ChristineT
- cbrxMay 19, 2020Star
ChristineT, it seems support updated my purchase date to the correct date, but when I log in, I still can't do anything as that date passed while in the process of trying to figure it out. My year long warranty expired 4-22, and as you can see by this thread, I was trying to get help well before that. What should the next step be?
- cbrxMay 28, 2020Star
ChristineT I need your help. Nothing has been solved, and I've been in the same boat for months now.
- FURRYe38May 28, 2020Guru - Experienced User
I would send her a private message as well.
