jeremyg237
Apr 09, 2018Luminary
XR500 What is your best ping playing PUBG XBOX.
I have a XBOX ONE X and of course a XR500. Other games etc I am running a low PING. However in PUBG I am getting a PING of 98-105 during game. Just wanting to see if everyone else is the same so I do...
Netduma_Jack
Apr 10, 2018NetDuma Partner
Hi Jeremy - since PUBG allows you to choose your own servers you are right to use Spectating Mode instead of filtering mode. Where are you located, and where are the servers you connect to located?
You can still take action to reduce lag. Try setting Anti-Bufferbloat to 70/70 and give your gaming device more bandwidth using Bandwidth Allocation.
The best way you could reduce your latency in PUBG is by improving your local network connection. This is a measure of your equipment, your line and your cables. To find out your line quality, run a PingPlotter test to check for spikes, jitter and other issues.
I hope this helps!
