ZiM988
Oct 27, 2021Aspirant
XR500 what should I do? Upgrading Modem
Hi I'm new here I'm an owner of an xr500 I have Xfinity gigabit internet I'm currently using the xb7 with it in bridge mode and the xr500 as my router I've been having more problems with Comcast then ...
ZiM988
Okay I agree on the router I already have it but my main question was about the modem part would getting the CM 2000 be my best choice or could I get the cax 80 router modem combo disable the Wi-Fi part of it and still use the xr500 or get the cm2000<xr500<S8000<every other device?
Netduma-Fraser
Oct 27, 2021NetDuma Partner
If you're planning to use the XR then you don't need a router modem/combo - as all it will be doing is passing traffic direct to the XR so you would be paying more to have it function as a basic modem. Any modem should work really!
