Seanabong2200
Sep 28, 2018Apprentice
XR500 wifi calling is really bad
So i bought the XR500 last month and since i have bought this router ive had a lot of problems. But for this post im going to stick to the wifi calling. Everything time i use the WiFI feature is not ...
Seanabong2200
Oct 02, 2018Apprentice
Netduma_Jack wrote:
Hi Sean - it's tricky to help you with this one as it's a NETGEAR issue. Do you have Smart Connect on WiFi enabled? If not, do you know which band you are connecting to (5GHz or 2.4GHz)?
I often find WiFi calling takes about 10-30 seconds to activate when I first connect to the router. I assume you are not seeing it at all over a period of time?
my wifes phone and my phone are connected to the 5GHZ. my yeah it usally takes about 30 seconds to start ringing but also at times it will not ring at all. smart connect is enabled ive disasbled and it and nothing changed. i have the iphone 8plus my wife has the iphone10x or whatever it is called she has hdr-10 on hers. my netgear r7000 was great with wifi calling up until i got this one. smart connect was turned on also for that router as well
Netduma-Fraser
Oct 02, 2018NetDuma Partner
I'd recommend calling Netgear support, they should be able to help you resolve this issue.
