Seanabong2200
Sep 28, 2018Apprentice
XR500 wifi calling is really bad
So i bought the XR500 last month and since i have bought this router ive had a lot of problems. But for this post im going to stick to the wifi calling. Everything time i use the WiFI feature is not ...
Retired_Member
Dec 27, 2018Appreciate the suggestions.
Smart Connect, Beamforming and MIMO are all enabled. I am connected to the 5Ghz band Channel 161 after doing a quick scan in my neighbourhood as it's the least congested. Security mode is WPA2 with AES. Unfortunately, so luck still.
I have disabled 11K too. Is it safe to keep it disabled or should I re-enable it? What does it do?
Dec 27, 2018Guru - Experienced User
Lets try disabling Smart Connect and MIMO and test again on 5ghz.
What OS version is loaded on the phone?
11k is Fast Roaming. It can be left disabled. You can enable it later again if you want to try it.
- Retired_MemberDec 27, 2018
No luck with disabling MIMO either.
What settings do you use? Perhaps it'll be easier if I just follow your config and troubleshoot from there.
I am currently on iOS 12.1.2.
- FURRYe38Dec 27, 2018Guru - Experienced User
I use Smart Connect and Beamforming. Manual channels 11 and 36. MIMO and 11k is disabled for me. However I'm using iOS 11.4. I'm seeing various posts about users having bad expeirneces with iOS 12. Something you may want to also look into. So some searching on apple suppot forums as well.
Is this the only phone you have when using it with the XR router? Any friends or family you can have come over and run some quick tests with? If those have problems as well, check iOS versions.
Try this, disable WPA security temporarily on the XR router. Have the phone reconnect to the open SSID. Test. Same thing still happening? Re-enable WPA2 and AES only after checking.
I presume this would need to be reviewed by NG support.
I would file a support ticket here:
https://www.netgear.com/mynetgear/registration/login.aspx
Yup, just tested with manual channels 1 and 161. 11K and WPA disabled.
My family members all use iPhone and previously had no issues with Wifi Calling on our previous routers. Only happened after switching to the XR500.
Appreciate you taking time to help out! One last question, do you have UPnP enabled? I had it disabled on my previous routers and could still get Wifi Calling to work. I have tested with it enabled and disabled to no avail.
