X_BEOX
Mar 14, 2020Guide
XR500 wifi connection delays
I am having a problem with wifi. Devices take 5 minutes or more to connect. And since some devices like my Roku TV time out before then, they won't connect at all. This happens on iPhones, iPads, App...
Netduma-Fraser
Mar 15, 2020NetDuma Partner
Sorry to hear you're having this issue, I would first suggest you disable Smart Connect in WiFi settings and try connecting manually to 2.4/5GHz and seeing if that improves the issue.
X_BEOX
Mar 15, 2020Guide
Thanks. Did that. Actually started a new wifi and made sure not to select that. Worked great for an hour but returned to same issue. Sometimes after a reboot it is fine but doesn't seem to last. I have no gear between my internet line and the xr500.
