Axelrod360
Aug 18, 2019Tutor
XR500 WiFi connection problems
I just got the XR500 last week. My problem is when I reboot my router, only about half my WiFi devices work at a time (about 10/26ish). Every once in a while I'll get lucky and they'll all work like ...
- Aug 19, 2019
I found the issue... kind of. I tried various older versions of the firmware and found version 2.2.1.10 is stable. I'm going to post this problem in the NetDuma forums and see if they have any suggestions. I don't want to be running an old version of the firmware on a router I just purchased. That doesn't give me confidence for the future support.
Aug 20, 2019Guru - Experienced User
Ensure the wifi on the ISP modem is fully disabled.
Try disabling Smart Connect on the router. Or enable Smart Connect if it's disabled...
Axelrod360 wrote:I just got the XR500 last week. My problem is when I reboot my router, only about half my WiFi devices work at a time (about 10/26ish). Every once in a while I'll get lucky and they'll all work like what's happening right now. Usually it also helps when I toggle QoS for some reason.
I'm behind an AT&T modem/route but have IP passthrough turned on so it shouldn't be getting in the way anymore. I've done numerous factory resets of both my modem/router and my XR500 with different settings and order of operations. Can anyone help me figure out what to do to fix this? I'm on the latest XR500 firmware. I contacted both Netgear and AT&T support and am just waiting for Netgear to call me back hopefully today since my case was escalated.
Axelrod360
Aug 20, 2019Tutor
The modem's WiFi is disabled, I tried mannually setting other channels on the Nighthawk, and yes I have other neighbors but it never was enough to affect the modem's WiFi which lead me to believe it's the router. On the NetDuma forum I made a post about my progress. I found that firmware version 2.2.1.10 works perfectly fine but not 2.3.2.56 so it seems to be a firmware issue. Right now I'm trying to nail down which version specifically made it stop working.
- FURRYe38Aug 20, 2019Guru - Experienced User
Did you happen to performed a factory reset and setup from scratch after v56 was loaded?
- Axelrod360Aug 20, 2019Tutor
Yes, every time I changed firmware I'd do a factory reset in incognito mode so cache wouldn't cause problems.
Ok, just checking. Something you might file a support ticket for and let NG support know about this...
