Wildfang392
May 03, 2020Tutor
XR500 Wifi Connectivity Issues.
Hello everyone! Wondering if anyone else is having this issue after the latest FW. V2.3.2.56. Not long after updating, I am having an issue that no matter how many devices are connected wirelessly, ...
May 07, 2020Guru - Experienced User
Has a factory reset and setup from scratch been performed since last update?
What version of FW was loaded prior to updating FW?
Wildfang392 wrote:Hello everyone!
Wondering if anyone else is having this issue after the latest FW. V2.3.2.56. Not long after updating, I am having an issue that no matter how many devices are connected wirelessly, after a while (say maybe 1-2 hours) the device's connection to the internet will stop while still reporting being connected to the wifi. Then after a few minutes the internet connection will resume on it's own or in extreme cases will have to reboot the router. I have reflashed the router with the latest firmware, ensured antennas are securely connected, changed networks from 2.4 and 5ghz into smart wifi, changed wifi channels, reset to factory, reset connecting devices wifi settings, and verified that hardwired devices are still connected to the internet. Router is 2-3 years old probably now. Nearing it's Eol? Any suggestions are appretiated!
- Netduma-FraserMay 07, 2020NetDuma PartnerHow long is it before the issue occurs again now? If you go to Settings > Monitoring > Connection status, what does it say for DHCP Lease obtained/expires?
- Wildfang392May 11, 2020Tutor
You mean the log when the dchp lease changes? It looks like it's fine unless there's something I'm missing.
Monday, May 11, 2020 21:46:09 [Internet connected] IP address: 184.166.52.***, Monday, May 11, 2020 21:45:50 [DoS Attack: SYN/ACK Scan] from source: 54.37.245.203, port 10222, Monday, May 11, 2020 21:43:58 [DoS Attack: RST Scan] from source: 49.51.65.219, port 10012, Monday, May 11, 2020 21:09:45 [DoS Attack: RST Scan] from source: 170.106.134.244, port 65010, Monday, May 11, 2020 21:09:44 [DoS Attack: RST Scan] from source: 49.51.65.243, port 443, Monday, May 11, 2020 21:09:42 [DoS Attack: RST Scan] from source: 49.51.65.219, port 80, Monday, May 11, 2020 21:05:36 [DoS Attack: SYN/ACK Scan] from source: 76.118.59.241, port 53, Monday, May 11, 2020 20:54:51 [DumaOS] DHCP lease change., Monday, May 11, 2020 20:54:29 [DumaOS] DHCP new event., Monday, May 11, 2020 20:54:29 [DHCP IP: 192.168.1.5] to MAC address 1a:f8:cb:66:f3:5a, Monday, May 11, 2020 20:54:29 [DumaOS] DHCP lease change., Monday, May 11, 2020 20:54:26 [DumaOS] DHCP new event., Monday, May 11, 2020 20:54:26 [DHCP IP: 192.168.1.5] to MAC address 1a:f8:cb:66:f3:5a, Monday, May 11, 2020 20:54:26 [DumaOS] DHCP lease change., Monday, May 11, 2020 20:54:25 [DumaOS] DHCP new event., Monday, May 11, 2020 20:54:25
Any other ideas appreciated. - Wildfang392May 11, 2020Tutor
interesting? Not entirely sure
[DumaOS] Error parsing line in ARP table: 'fe80::d64d:a4ff:fe22:f885 dev br0 lladdr d4:4d:a4:22:f8:85 STALE', Monday, May 11, 2020 18:55:56 [DumaOS] Error parsing line in ARP table: 'fe80::201:5cff:fe6b:cc46 dev brwan lladdr 00:01:5c:6b:cc:46 router REACHABLE', Monday, May 11, 2020 18:55:56 [DumaOS] Error parsing line in ARP table: 'fe80::ce40:d0ff:fe5c:737e dev br0 lladdr cc:40:d0:5c:73:7e router STALE', Monday, May 11, 2020 18:55:56 [DumaOS] Error parsing line in ARP table: '2600:6c67:687f:f80f:840c:3f29:2c1d:b07b dev br0 lladdr d4:4d:a4:22:f8:85 REACHABLE', Monday, May 11, 2020 18:55:56 [DumaOS] Error parsing line in ARP table: 'fe80::b06f:c2d4:3d10:b8d8 dev br0 lladdr 2c:54:91:91:1a:ca STALE', Monday, May 11, 2020 18:55:56 [DumaOS] Error parsing line in ARP table: '2600:6c67:687f:f80f:2882:d5f:67dc:6c64 dev br0 INCOMPLETE', Monday, May 11, 2020 18:55:56 [DumaOS] Error parsing line in ARP table: 'fe80::d64d:a4ff:fe22:f885 dev br0 lladdr d4:4d:a4:22:f8:85 STALE', Monday, May 11, 2020 18:55:41 [DumaOS] Error parsing line in ARP table: 'fe80::201:5cff:fe6b:cc46 dev brwan lladdr 00:01:5c:6b:cc:46 router REACHABLE', Monday, May 11, 2020 18:55:41 [DumaOS] Error parsing line in ARP table: '2600:6c67:687f:f80f:840c:3f29:2c1d:b07b dev br0 lladdr d4:4d:a4:22:f8:85 REACHABLE', Monday, May 11, 2020 18:55:41 [DumaOS] Error parsing line in ARP table: '2600:6c67:687f:f80f:2882:d5f:67dc:6c64 dev br0 INCOMPLETE', Monday, May 11, 2020 18:55:41
I'd say there are 11 networks near me with 4 in close range proximity. I have reset the router to factory and also reflashed the firmware with the same version. It isn't happening as much but still occasionally occurs. I have changed my network channels, maybe i should see if i can figure out what the neighboring network channels are if it can show me.
- FURRYe38May 12, 2020Guru - Experienced User
If you have some wifi neighbors near by, try turning down the power output of the wifi radios to see if this helps any. Sometimes reducing the wifi foot print interaction with other wifi signals can help with odd wifi disconnetion issue when in a wifi congested envrionment.
Wildfang392 wrote:I'd say there are 11 networks near me with 4 in close range proximity. I have reset the router to factory and also reflashed the firmware with the same version. It isn't happening as much but still occasionally occurs. I have changed my network channels, maybe i should see if i can figure out what the neighboring network channels are if it can show me.
- Netduma-FraserMay 12, 2020NetDuma PartnerThe log is fine, they're common entries. Actually go to Settings > Monitoring > Connection status. Then let us know what it says for DHCP Lease obtained/expires.
