ErwinZ's avatar
ErwinZ
Tutor
Mar 15, 2019
XR500 Wifi network connection issues with Apple devices
Hi All,
Ever since I have the XR500, I'm encountering Wifi connection troubles, that I never had with my previous router. We have several Apple devices (mainly Iphones and Ipads), that all show troubles in getting a Wifi connection. Often the wifi settings show the error "No Internet Connection". Sometimes it helps switching the Wifi of the Apple device off and on again. Sometimes it helps trying to connect to the Wifi network at another frequency (from 5 GHz to 2.4 GHz, or vice versa). But even when a Wifi connection has been established, it sometimes just drops, requiring to repeat the steps just mentioned.
When a device gives the "No Internet Connection" error, other devices (both wired and using Wifi) are performing fine, showing that it has nothing to do with the external internet connection.
I even tried to use a static IP on the Apple devices, in order to exclude troubles in the DHCP protocol, but that didn't remove the Wifi connection troubles.
Does anyone has a suggestion how to solve this issue?
  • FURRYe38's avatar
    What FW is currently loaded?
    What WPA security modes are you using?
    Try enabling Beamforming and MIMO.
    ErwinZ wrote:
    Hi All,
    • Netduma_Jack's avatar
      Netduma_Jack
      NetDuma Partner
      Not sure if this will work, but try enabling the Guest Network and connecting your Apple devices to that instead. Worth a shot!
    • ErwinZ's avatar
      ErwinZ
      Tutor
      Dear Furry,
      Thank you for triggering me about the Wifi channels. I now noticed that auto channel selection is only possible for the 2.4 GHz bands, but not for the 5 GHz bands. In our living room we recieve more than 15 different Wifi routers and access points, so indeed the default channel 44 was in use by several others too. I now changed the channel number, and hopfully this will solve the issue.
      • FURRYe38's avatar
        Ok, yes wifi interferences can be problematic.
        Keep us posted if you seen more problems. Hopefully setting something different will help here.
        ErwinZ wrote:
        Dear Furry,
