Johnny_Cao1
Jun 20, 2021Aspirant
XR500 wifi No Internet
One day i was playing somegame but then noticed that i was lagging. So i thought i could fix it by resetting the router. After resetting the router and when i try to connect to it. it keeps saying No...
michaelkenward
Jun 21, 2021Guru - Experienced User
Hard to tell what is going wrong with so much missing detail from you.
Start by telling people what the modem is in front of the router.
Johnny_Cao1 wrote:
Please help me i've been resetting the router many times but all show the same result.
That's going to get you nowhere if you keep getting it wrong.
As this is a router, there is probably a modem sitting in front of it. You need to get the devices to forget any inherited settings. Among other things, that means rebooting the network.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
The XR500 is a Gaming Router. You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so there may be useful responses here, but the XR500 has its own operating system and is not like the average Nighthawk router, you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
