Johnny_Cao1
Jun 20, 2021Aspirant
XR500 wifi No Internet
One day i was playing somegame but then noticed that i was lagging. So i thought i could fix it by resetting the router. After resetting the router and when i try to connect to it. it keeps saying No...
Johnny_Cao1
Jul 12, 2021Aspirant
its in router mode and its just my pc that doesnt show up in the network list. Other devices can see the wifi and connect to it while my pc doesnt show any sign of the router.
Netduma-Fraser wrote:
What is your modem model that the XR is connected to? Do other devices get an internet connection through the router or is it just the PC?
Netduma-Liam
Jul 12, 2021NetDuma Partner
After resetting the XR, you'll need to go back to the interface at 192.168.1.1 or routerlogin.net and complete the setup wizard, you won't have an internet connection until you've completed this.
- Johnny_Cao1Jul 13, 2021Aspirant
Netduma-Liam wrote:After resetting the XR, you'll need to go back to the interface at 192.168.1.1 or routerlogin.net and complete the setup wizard, you won't have an internet connection until you've completed this.
The thing is. I can't find the wifi on the network list. for eg: NETGEAR97
It just wont show any sign of the Xr500 wifi.- Netduma-LiamJul 14, 2021NetDuma Partner
I'd suggest running through the setup wizard while connected to the XR500 via ethernet, you should then be able to connect to the XR500 via wireless after this.
- Johnny_Cao1Jul 16, 2021Aspirant
Netduma-Liam wrote:I'd suggest running through the setup wizard while connected to the XR500 via ethernet, you should then be able to connect to the XR500 via wireless after this.
Do you have to connect the ethernet cable to my pc? Because if you do i dont have a long enough to connect it to my pc.
