Oldmannow
Sep 16, 2019Follower
Xr500 wifi on only one lan port
Was in storage a few months and before using I manually updated to the latest firmware. I can only get internet on one lan port at a time and wifi works fine. Plug my decktop into any port and work...
michaelkenward
Sep 17, 2019Guru - Experienced User
Hard to unravel that information dump. Too much going on.
What has this got to do with your router?
Oldmannow wrote:
Phone has dial tone but cannot receive calls.
This bit is stuck in the middle there:
Oldmannow wrote:
router displays an amber light and laptop says "no internet".
Maybe that is the key detail. The rest is just distraction.
It may help to reboot the whole network in the right order.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it connect.
- Turn on computers and rest of network.
You might get better and quicker replies, and find other answers, over in the appropriate section for your device:
Nighthawk Pro Gaming Routers - NETGEAR Communities
- Netduma-FraserSep 17, 2019NetDuma PartnerWhat is your exact physical setup? Is the WAN port correctly connected to the modem?
