PG1211
Jan 09, 2021Aspirant
XR500 Wifi Randomly Stopped and will not reconnect
I randomly had all wifi devices go offline. I looked an in the Device manager only deviced wired (my PC) works. No settings have changed. All wifi devices show offline as there is no wifi signal. Whe...
PG1211
I also tried plugging another router into the XR and a gaming system. Those both show and work fine as well. Just everything wifi doesn't. I can use everything on wifi through the other router but obviously I don't want to set up things on another network for 30 devices.
No1Mportnt
Jan 09, 2021Luminary
Did your firmware get updated? What version of firmware are you running?
Sounds like there may be a hardware failure with the wireless module in the router.
- PG1211Jan 09, 2021Aspirant
I am running V2.3.2.104-DumaOS3.0-Beta, everything was fine until this morning.
I just went to firmware V2.3.2.66 to see if that helps and it didn't fix anything.
- No1MportntJan 09, 2021Luminary
Since you have tried a different firmware with the same results I would suspect a hardware failure.
