BmoreBateman
Nov 08, 2019Guide
XR500 Wifi Slows to a crawl
Hey everyone, I have been banging my head against the wall the last few days. I have been having a issue with my XR500 that I have had for awhile now. I cannot seem to keep my wifi speeds stab...
- Nov 18, 2019
Great News! I rolled back the firmware, replaced the power cord because it randomly went into a boot loop on .32, Moved the router in a Upstairs closet on the other side of the floor... everything has held stable. I even updated the firmware to the current version Friday night. Everything has held strong in that time. I'm saying I was either getting really bad interference where it was at or the power cable was failing and wasn't providing enough power.
Nov 08, 2019Guru - Experienced User
Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Set 20/40Mhz Coexistence to 40Mhz only.
Is Smart connect enabled or disabled?
- BmoreBatemanNov 08, 2019Guide
Hey thanks for the reply. I have done a channel scan and verified that channel 8 was empty on 2.4Ghz so I'm using that, 136 on 5Ghz. I live in a townhome complex so i have alot of people near by. I can see 40 devices when I did my Channel scan.
Beamforming was on by default and i toggled the 20/40 Coexistence with no success.
Smart connect is on currently.
- Netduma-FraserNov 08, 2019NetDuma PartnerJust to confirm your disabled QoS completely from the Anti-Bufferbloat 3 line menu and still suffering from slow speeds? What speeds do you get when you're using a wired connection? Disable smart connect and connect to 5GHz manually, are the speeds still slower?
Yes I disabled QoS completely.
I am normally pulling 850Mbps from Fast.com on a wired connection
I just got home and disabled smart connect and wow im seeing such a difference.when its on, sometimes not loading pages to the best of 30Mbps (not consistant) and when its off I am suddenly getting 640Mbps.
Why would smart connect/my 2.4Ghz be having such a issue? its the only one in its channel and i see this on the channel wireless scan
Channel 4; Rssi -16; Noise -87 and 40MHz (coexistence is off at the moment)
